-   -   Steering adjustment? (https://www.offshoreonly.com/forums/general-q/189207-steering-adjustment.html)
cougar25 06-19-2008 06:17 AM
While driving the boat (502/bravo 1 setup) when coming off the throttle the boat will hook to the left out of nowhere feels very unstable but i am able to get it back under control. Sometimes happens when I go on an angle across another boats wake. When I was talking to someone about it he said he has the same thing going on. Told me to raise the outdrive and he moved it from side to side saying there was too much play in it. He said I need a new transom shield which I have never heard of. It does seem to have excessive play 4 inches on either side. Thanks for any help
Dave M 06-19-2008 08:54 AM
Sounds like it could be a worn gimbal ring.
cougar25 06-21-2008 10:46 AM
How long can I let this go for? Not really in a financial position to fix anything major at this time.
cougar25 06-21-2008 10:47 AM
beter yet is it safe to run it as long as I don't beat on the boat?
Griff 06-21-2008 11:11 AM
That would depend on how bad it is.
stevesxm 06-21-2008 04:59 PM
all the rams back there have big rubber bushings in them... if they fall to bits or the bolts loosen up the drives will steer all the hell over the place and do exactly this... look at them really carefully before you get hurt or break something badly.
i have seen this more than once.
