Hyd steering presure adjust at idel?
Since the suprercharger last summer, I noticed my hydraulic steering has become tough to work when docking at idel. Bump up the rpm to 1000 and it's fine. Is there a presure adjust to this system. The pump is stock, Merc hp500efi, the rest of the system is IMCO .
Add on or full Hyd?
RPM is the factor, so I assume you dropped the idle RPM from the motor change? |
I have the same problem, has done since installed, full hyd, with power assist, Imco sys. 1000 - 1200 rpm great, under 1000 harder than H---
Larry |
Full hydraulic should not be hard to turn at idle. I can turn mine with 2 fingers at a 700rpm idle. There is an orifice fitting you can drill out where the high pressure hose connects to the pump also.
Originally Posted by Griff
(Post 2597091)
http://westtexasoffroad.homestead.co...rsteering.html Doug |
Originally Posted by Boatally Insane
(Post 2597522)
Here is a link to an article about this modification...:cool-smiley-011:
http://westtexasoffroad.homestead.co...rsteering.html Doug Larry |
Was the pulley ratio changed with the other changes?
Originally Posted by Falcon
(Post 2597725)
No same pulley, same RPM at idel, Full Hydraulic steering.
I've had the problem since the supercharger was put on. I'll read that article posted above. |
Maybe just a pulley change would be easier than removing the pump and drilling pieces out.
I'm going to try buying a smaller pulley first. |
smaller for the pump i presume... because it would have to be bigger for the crank... and thats my/our point... when the pulley stack on the crank got changed for the blower, my/our guess is that the crank pully got smaller at the same time somehow...
I would drill out the fitting, its easy to take out.Here is some picks of a 500efi pump
http://www.offshoreonly.com/forums/s...power+sterring I might have a extra orifice fitting out of a pump I could measure if wanted ? On my Scarab with the older design pump,Mayfair steering it was slow to turn at idle, the blower purged about 600rpm,so on the down cycle it was hard to turn. I had compared the orifice hole size to my 70 Chevelle, and the marine pump had a larger hole |
Drill it 11/64....per Imco
Ok, the boats at the cottage and I'm not back there till Firday night. I'll look and see if I can get that fitting out without too much disasemebly.
(Post 2597522)
http://westtexasoffroad.homestead.co...rsteering.html Doug Birdog, what do you mean by "....per imco" ? Is this what they recomend? I guess I could just try and call them. |
Originally Posted by Canada Jeff
(Post 2598355)
I've had the problem since the supercharger was put on. |
"US1 Fountain" is right. If nothing else has changed, something is wrong. Anything that may have changed should be checked. If there is a filter, replace it. If something else is restricting the flow, opening up the fitting may not help.
I'm not posative the main crank pulley wasn't changed. The supercharger pulley sits infront of the main pulley, so it shouldn't have been changed. But I havn't confirmed this.
1 Attachment(s)
Here is a pic I took last year after the install. Kinda hard to see, but it looks like the original pulley (which is blue) is still there. I'm going to send an E-Mail to Dustin and ask if there is a new main pulley with this kit.
That would explain everything. |
You have the same set up as me ,Mine idles around 750-800 if its alittle lower that 750 you can feel its a little stiff, But it only when I'm parking it.Being your is a single your turning it a lot more. I found that I had around 150-200psi restriction we determined it had to be a hose end, I thought it was causing a hard to turn steering and it ended up being the plastic bushing and bearing in the Marine machine hub,Falcon is very knowledgeable on this, he and other posted a bunch of info on my thread.
heres a thread on the hose....http://www.offshoreonly.com/forums/s...hydraulic+hose I have had 3 go bad so more than likely thats were its coming apart on the inside and could of caused the restriction .I was told around 50psi is around norm on the free flow of the fluid, The gage ckecker I made up is easy.#6 gage adapter and a nos gage,put it inline were the filter is just for the test, bench testing it would get up to 1500 making it build pres, by crimping the hose, useinga 1/2 drill if you crimp the hose all the way dead heading it will stop the drill and and spin back,tuff on the wrist. Also you can make a union for the filter which would bypass the filter to se if it helps , The filter element is a wire mesh , cleanable, I didn't see any restriction in mine,hope some of this helps,Rob:D |
I have read through your thread Strip. I am going through a process of elimination right now. My first step is to confrim the whiple kit didn't changed the main puley. Then, I'll check for a crimped line this weekend. After that, I will concentrate on the pump. Thats where your thread will be read, and re-read I'm sure.
Is your WP lower now too as compared to previously since the SC install?
(Post 2600652)
Originally Posted by US1 Fountain
(Post 2601081)
the kit comes witha restrictor,Whipple wants it to run cold,
The water crossover prop made a diff in press and does yours have the whipple fuel cooler? |
Originally Posted by Strip Poker 388
(Post 2602244)
The water crossover prop made a diff in press and does yours have the whipple fuel cooler? As for the cool fuel from Whipple, I don't know. I don't think so. |
| All times are GMT -5. The time now is 01:10 AM. |
