Hesitation problem under load 454 Magnum, I need some idea's
Well for the timing on that bird, I would shoot for about 36 fully advanced, which is usually about 3000 RPMs. To check you fuel pressure you need to install a gauge in line up near the carb. It should be roughly between 5-8 psi depending on pump.
Put a new set of the NGK's in, and connected the choke with a temp wire (carb rebuilders lost mine, so new one on order)
And seems to be running great!
Thanks for all the help!
2Slow4me
9
08-02-2007 03:35 AM
