-   -   wiring trim switches (https://www.offshoreonly.com/forums/general-q/189658-wiring-trim-switches.html)
showtime83 06-25-2008 01:51 PM
i have the carlingswitches, 20amp 12 v, have 6 prongs, 3 on each side, how do i wire these? i would guess power into the middle one, then power out on the top and bottom to the pumps?however that way would only use 3 of the 6 prongs, what am i missing? grounds for each one? did alot of searching but couldnt find much, thanks
MOBILEMERCMAN 06-25-2008 02:04 PM
You can use a single pole{ 3 wire} or double pole {6 wire} switch. Generally the double gets used as a both drive switch. You can use either side. Each side needs its own power to the center.
Kims 06-25-2008 03:44 PM
Send me an email to [email protected] and I will make you a diagram...
Kims 06-25-2008 04:16 PM
Here is one for a normal trimtab switch setup:
http://inlinethumb53.webshots.com/42...600x600Q85.jpg
Here is one for a triple engine trim setup with two separate "lift all" switches"..
http://inlinethumb34.webshots.com/40...600x600Q85.jpg
Let me know if you need any more...
showtime83 06-26-2008 09:41 AM
that should do it, thanks!
