installed crossovers now no water temp
1 Attachment(s)
needle will barely move off 100deg.......got lots of oil temp though.......is this normal for crossovers??
Assume no theromstat, yes.
A restrictor might help, but watch your water pressure. |
Hi,
With out a thermostat I dont believe that you will achieve a higer temp. Which is really what you want. You need to run a thermostat housing with a bypass. It would have a fitting in the front of the housing that would connect to the middle of the cross over. Stainless marine makes just the one or eddie marine. Then you will be able to run a thermostat and get atleast 120-125 water temps. You will have to drill 3 small holes in the stat for relief and even temps through out the rpm band. (T-stat 160Deg) (Worked For Me) Hope this helps Brian |
that is true, I had a crossover with no provsion for a by pass and the same deal, way to cold..gets condensation in the engines, waiting on one now from eddie to run a bypass, Rob
Originally Posted by pullmytrigger
(Post 2602954)
1 Attachment(s)
heres a closer pic of the set up......so I would put a hose fitting into the brass plug then get a new t stat housing????
1 Attachment(s)
(Post 2604625)
Originally Posted by BY U BOY
(Post 2604721)
That is correct.
I am in Vt and have had nothing but problems with the t-stats. temp gauge spiking when coming off plane. Drilled holes in stat and made it worst...temp gauge spiked while running. Finally just took them out. Going to have to change oil more often.
(Post 2604771)
how does that help the engines warm up......???
| All times are GMT -5. The time now is 02:36 PM. |
