-   -   Aftermarket temp sender on 496ho (https://www.offshoreonly.com/forums/general-q/189772-aftermarket-temp-sender-496ho.html)
22 DAYTONA 06-27-2008 10:47 AM
I added new guages and need to change the temp sender on a 496 ho. The procomp sending unit and adapters are not the size of the original sender. Is there another place on the block for a sending unit or is there some kind of special adapter. The original sender does not work well with the new guage. Thanks ahead for the help.
LAKESIDE RESTORATIONS 06-28-2008 07:52 AM
If it is smaller you can use a bushing. If it isnt you are kinda SOL.. I know that Livorsi makes one that will fit.. Jamie / Lakeside
22 DAYTONA 07-01-2008 11:17 AM
Thanks Jamie,
The adapters for the sending unit are american pipe thread and the stock sending unit looks to be a metric pipe thread.
LAKESIDE RESTORATIONS 07-01-2008 11:20 AM
I replaced the sender in my 496 Mag HO with a livorsi unit when I installed my Whipple. It threaded right in & no leaks.. ;) Jamie / Lakeside
two-rocks 07-01-2008 03:35 PM
Anyone know the thread for these holes on the 496 manifolds?
I'm freshwater cooling mine and need tp plug the holes with something (using them on a 454). Currently have a 3/8-16 bolt in there with a heavy wrap of Teflon tape, and yes they leak. Only ran it on the engine cradle - now it's in the boat and this is on my list of 'stuff' to address before I splash.
Thanks.
22 DAYTONA 07-02-2008 03:20 PM
I wonder if the livorsey and the autometer sending units are the same. I could just buy a livorsey.
