Motor Question
my .02
well... we've had this discussion before. the drag profile of this boat is very high at 70 mph. you need a LOT more hp to go only a little bit faster and there are a dozen threads here that deal with those ACCURATE mathematics. two things strike me here...
1) there is nothing in the work thats been done to suggest a giant increase in power
2) the original combination that seemed to work well, has been comprehensively changed to some OTHER combination of unknown capability.
you say it runs great down low but won't pull up top... yet thats what you told them to do. if someone said that to me , the cam would go in well advanced and the i would be after big port velocity as opposed to big flow numbers... yet it seems that you went after the flow numbers as well...
i wonder if the combination is just wrong and while you have punched up the middle it falls over and runs out of torque too soon up top.
spend the money. go to the dyno and find out the truth before you piss away the summer and a bunch of money guessing.
If the cam specs where posted I apologize for asking since I only saw lift figures.
What are the seat, duration at .050", LSA, or better yet Manufacturer and cam part# ?
I know Comp makes some 'snotty' lobes with mid .500's lift so I wonder why we think the cam he has is close to 420 Specs ? As far as I read, we don't know.
Again, if I missed the specs, I apologize for the questions/statements.
I have a stroker 496 with a larger custom cam ported and flowed; rpm-air-gap with 1" spacer headers and no mufflers; the boat has a ton of more power low and midrange it is much much quicker but top speed is the same. Shouldn't I be able to turn the top end rpm's more?
Could it be some of the other problems that some of the other guys have suggested???---YES! I'm not discounting any of that, but if the engine is telling you all the power is from low to midrange then the torque range needs to move towards the RPM scale from midrange to top end side. Just a suggestion---something you might consider. Hope it goes well for you.
