-   -   hp 500 cam (https://www.offshoreonly.com/forums/general-q/190168-hp-500-cam.html)
sandcraft 07-02-2008 10:20 PM
hp 500 cam
Can anyone tell me the cam specs that Mercury racing used for thier 500 bulldogs? Thanks
Griff 07-03-2008 12:52 AM
I'm pretty sure it was the same cam used in the HP500 carbed engines. I don't have my HP book with the specs anymore.
Canada Jeff 07-03-2008 06:34 AM
The "Bulldog" is not an hp500.
Your thread topic doesn't match your question.
What cam are you looking for, the "Bulldog" cam or the HP500 Cam?
SB 07-03-2008 07:31 AM
HP500 (hydr roller) and Bulldog 540 (hydr flat tappet) cams are very different - not even same type.
In my notes I have the Bulldog 540 as having:
Crane Flat Tappet Hydraulic Cam
240, 250 at .050"
.559", .578" lift
110LSA
Cam installed 5 advanced (105ICL)
I believe grind # H-240/329-2-10 ???
Always double check someone's notes befor you 100% believe it. :D
sandcraft 07-03-2008 08:00 AM
Sorry, I thought the bulldog was the same as an hp 500. I need specs for the hyd roller. This is for a carbed engine. Thanks.
SB 07-03-2008 08:18 AM
Merc HP500 Carb
Grind#HR-284-2S-10IG
Adv 284, 292 at .004” Lift with 1.7 .576 / .598
At .050” 222, 230
ICL 105, ECL 115
LSA 110
sandcraft 07-03-2008 09:36 AM
Thanks a bunch, ya'll were a bigger help than merc racing.
