-   -   1996 7.4 carb. ignition timing (https://www.offshoreonly.com/forums/general-q/190810-1996-7-4-carb-ignition-timing.html)
JIM H 07-11-2008 02:03 PM
I need the procedure on timing.
Thanks is advance
Jim H
hoozeyurdaddy 07-12-2008 08:49 AM
nothing hi-tech here, should have a 20 or 24 deg. module, just set base timing at 8 deg. and check the max timing, should be you 8 deg plus what ever the module is. should run good between 32 and 36 deg. max advance. make sure you check your max adv. with engine at 3000rpm or a little higher.
JIM H 07-12-2008 12:44 PM
Thank You
I was told that i have to ground out a purple wire with a white tracer.
If i need to make any adjustments. Is that so ?
hoozeyurdaddy 07-12-2008 05:15 PM
thats not needed with your set up, just set it.
Larry
