thank you I will try that this week end,when I rotate the props what can I expect the boat to do and can I run it wot?
same issue on my 2001 353 fastech
I just re-installed my motors after repowering the 496 ho with upgraded pistons 5 lb procharged etc,etc,etc
I am not sure if I still have the rpm difference like before doing the upgrade ...my feeling always was that the fuel pump or screen was getting clogged or blocked at higher rpm I had a 200-250 rpm difference mine was at wot or above 4600rpm I know in the past 496 motors had issues with debris clogging the fuel pump because the filter is after the pump..496 have 2 fuel pumps 1 (boost pump l/s of engine in front of fuel water seperaotor)that draws the fuel from the tank and 1 that is on the r/s of engine which sends fuel to the rails. |
Originally Posted by sonic28
(Post 2625154)
Carder PS: did you check the magnets in the upper drives for any bearing or gear material sticking to them? |
are we sure you just don't have a cam lobe leaving town ? or as happened before here, that you didn't get the firing order wrong on that motor somehow before all this started...
the firing order is fine when I replaced the plug I do one at a time also use a scope to see how it was firing.
could be a bad throttle cable, they can get stretched over time
| All times are GMT -5. The time now is 03:37 AM. |
