No spark with MSD all in one
Over the weekend i was running fine and all at once lost spark, also tach. Really wierd but the coil came loose from the holder and was dangling at the back of the engine. I grabbed the coil and found a broken wire at one of the terminals (the tach wire) and the spark wire going to the dirstibuter cap was broken at the top of the coil. So i replaced the coil and the coil wire, tightened everything back down and still no spark. I have the MSD "all in one", 8560 i think, and i was thinking the only thing left would be the pick-up in the dist itself, right? Can these be changed out? Where could i get a pick-up for this dist other than MSD if it is available? Thanks, MIKE
1 Attachment(s)
yes you can .... 84661 ....
http://store.summitracing.com/partde...5&autoview=sku All MSD billet distributors use the same pickup ...They do go "bad" ...... you might try local speed shop .....should be about 20.00 ..... m |
| All times are GMT -5. The time now is 01:00 AM. |
