-   -   Buna-n Orings ok to use for Captains Call actuator??? (https://www.offshoreonly.com/forums/general-q/191428-buna-n-orings-ok-use-captains-call-actuator.html)
PSDfreak 07-19-2008 06:14 PM
I need to replace the small o-rings that seal the water from coming out of the exhaust pipes at the actuator opening for the captains call exhaust solenoid. There are two small o-rings on the actuator rod that goes into the pipe which the flapper screws onto.
I went down to my local autoparts store and found what looks to be the right size orings so I got them. They are made out of "Buna-n" which is nitrile as I understand. My concern is, will this material be ok to use? They are black o-rings...The original o-rings I pulled are orange. I would imagine that with water going through the exhaust pipes it doesnt get TOO terribly hot.
Any words of wisdom?
Thanks,
Casey
PSDfreak 07-19-2008 06:45 PM
Doing some further looking around online it seems like I am seeing that Buna-N orings are good for 250-300*F. Now the question...How hot do the pipes get with fresh water running through them??
Blueabyss 09-04-2008 09:51 AM
Captains Call
I am havving the same problem with my captains call exhaust. Did you try the buna plugs?? Did it work??
Chris
stevesxm 09-04-2008 10:18 AM
the orange ones are hi temp. if they came that way from the factory, that should tell you something. im sure the black ones will work initially but are likely to get hard like coal and fail in fairly short order.
Ken N 09-04-2008 11:47 AM
Call Corsa Marine (1-800-486-0999) that is there teck line.
Maybe they have a replacement O rings
