-   -   questions for 500hp owners (dont hate me) (https://www.offshoreonly.com/forums/general-q/191600-questions-500hp-owners-dont-hate-me.html)
fotoboy 07-22-2008 01:29 AM
I have a 500hp (blue motor) w a m1sc in a 67 prostreet camaro.
My question is the car guys all seem to think that this blower (very similar to a d1sc is too small for a 502. The kit I bought is specifically made for this engine and is suppose to produce 750 hp at 5 psi. I do not want to hurt this engine so I am def keeping it on pump gas friendly boost levels.
I just finished with the build and have yet to see what it will do.
http://i145.photobucket.com/albums/r...h_MVI_2392.jpg
http://i145.photobucket.com/albums/r...B0421-copy.jpg
fastlane40 07-22-2008 06:16 AM
I'd change to CMI's to eliminate reversion problems.
niceguy 07-22-2008 06:59 AM
Well if your trying to make the utmost power from that engine, then YES it is too small. I too am a car guy and have had to change my way of thinking since getting into boating.
The idea of putting this blower on a 502 is low boost and realiablity, all while making more power. If you are happy with your combo, then who cares what the other guys say?
t500hps 07-22-2008 07:49 AM
I bet your buddy drives FORD mustang too.....
So what if the boost is low. The engine should last awhile that way and still make decent power. Remember, the setup your running was intended to run at high RPM for extended periods of time, your drag racing it for 10-12 seconds at a time. The problem I see is that blower puts on the power at higher RPM and not making full power when you launch (or that could be a good thing depending on how you look at it)
750hp.....not really. That is what Procharger claims, but it's not making that. I had a pair of 500EFI's with 8 psi Prochargers and they were reported to be 830hp..actually dyno runs put them around 790hp....your probably in the high 6XX's IMO.
fotoboy 07-22-2008 09:41 AM
Not sure what CMI is. Lol this was on a Mustang forum too. THe car pulls low 1.5 60fts on motor soI wanted a blower that came in on the high side. Im assuming that I will have to go to a smaller pulley being I am running a rathere larger air to air intercooler instead of the small air to water int that came with the kit.
Thunderstruck 07-22-2008 10:51 AM
Great setup. I've seen another car w/ a blue merc motor in it and it ran great. Post some times once you get them.
Tom
PS CMI's are marine exhausts, he was just joking.
two-air 07-22-2008 08:35 PM
I thought the water reversion problem was with the HP500 Carb with the Gill exhuast.... That looks like an EFI:evilb: I think he's ok..
GO4BROKE 07-22-2008 08:54 PM
I always though they would be great car motors.
fotoboy 07-22-2008 10:58 PM
aumming the lower crank pully is 7.5 in, what size did you go on the blower to get 8 psi? right now I am running a 4in on top and going to get a 3.2 in tomorrow.
t500hps 07-23-2008 06:53 AM
I have no idea.....I bought the boat set-up that way. Once winter came I pulled all the stuff off and sold it. Ended up stroking it to a 540, ported Iron Eagle heads, porting the intake, oval throttle body, big cam, and upped compression to 9.75. Made 630HP and 700TQ fully dressed (with MY headers) on a dyno. I do know the 8 psi system usually came with a bigger intercooler so I couldn't tell you what might be needed for your set-up.
The 500efi is a great motor but it just looks weird seeing it inside a car!!!! :) (wouldn't it have been cheaper to use an "automotive" based engine for your build?)
