-   -   What kind of sea pumps are these? (https://www.offshoreonly.com/forums/general-q/191691-what-kind-sea-pumps-these.html)
Nordicflame 07-22-2008 10:29 PM
2 Attachment(s)
Can anyone ID these?
Thanks,
Dave
Mbam 07-23-2008 06:07 AM
I'ts a Mercury, was used before the current 2/3 piece style.
Uses the same impeller, bearings & seals as the newer one.
I think I still have a couple of them floating around.
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
Nordicflame 07-23-2008 07:04 AM
Thanks Marc...
They look pretty good actually and how would it be to change the impeller with only removing the rear plate and not everything else :)
I would assume the pressure output would be the same assuming the same impeller.
What would I need to rebuild these other than the impeller obviously? Any special tools?
Thanks,
Dave
Young Performance 07-23-2008 03:31 PM
All you will need is an impeller, unless it has a bad seal and is leaking. It uses the same impeller as the newer pumps and you don't need any special tools.
Eddie
Nordicflame 07-23-2008 03:37 PM
Thanks guys...!
