-   -   Merc timing V6 module/msd questions (https://www.offshoreonly.com/forums/general-q/191715-merc-timing-v6-module-msd-questions.html)
tssteph 07-23-2008 08:27 AM
Using a Mercury distrbutor with a V6 module is it possible to:
1. Use the distributor with a MSD box without using the merc module? In other words use the Merc dist a MSD box/timing control module and eliminate the V6 module.
I suspect the answer is no.
2. Can the timing be locked out with the Merc V6 module setup at all?
I suspect the answer is again no.
3. Can a MSD iginition box be used with the stock merc dist and v6 module? Is it a standard wireing setup that is included in the MSD installation instructions?
Little Tommy 07-23-2008 10:28 PM
The V6 Module and Mercury distributor along with MSD blue box work great. When you purchase the MSD box, the wiring diagram will explain how to hook-up the Mercury ignition. This combination has been used for years. It seems everyone ends up using this combination because they get fed-up with all the others. Hope this helps. LT
BenPerfected 07-24-2008 07:49 AM
Can someone scan and post the wiring diagram for the MSD/ Merc combination?
