-   -   454 magnum mpi idle help (https://www.offshoreonly.com/forums/general-q/192194-454-magnum-mpi-idle-help.html)
timowens35 07-29-2008 07:00 PM
My 1997 454 Magnum mpi seems to be idling too fast. It is at 800 rpm. It was my understanding this should be around 600. I ordered the merc manual, but I am impatient. Maybe I am just paranoid but, this boat is new to me and I just want to be sure.
Thanks for any help.
BGIII 07-29-2008 07:24 PM
Verify your tach before you freak too much.
Griff 07-30-2008 12:03 AM
800rpms is just fine for neutral idle speed. Might be a little high or the tach is off. It won't hurt anything either way.
timowens35 08-04-2008 10:17 AM
I took a closer look at things. The distributor cap had a bolt broke off. It was raised off the base about 1/4" on one side. Replaced cap and rotor and everything is back to normal.
