Bravo HP Gimbal ??
Hello,
How can you tell the difference between a standard bravo1 gimbal and the HP style and should there be any side to side movement in the bell housing it sides side to side but no play in the steering. Thanks Alec |
The HP gimble is thicker than the Bravo gimble and uses larger pins, its beefier all around. Also the HP Gimble cannot use the trim limit switch due to the thickness, mechanical indicators are needed. As far as play in it side to side, you should very little, maybe 40-50 thou :drink:
