coupler bad?
Whats it like when a coupler goes bad? I see lots of grease behind the motor and it seems to rev a little higher like it is slipping, is that indicative of it going out?
sounds like it might be going bad to me. What syle couplers do you have, the HD or standard units?? Are you sure it's grease or rubber?
Originally Posted by Panther
(Post 2670088)
Everyone I dusted ripped out the splines and was like the boat was in nuetral. There was no "starting to go about it". If the rubber let get like Panther said, you will have bits of rubber all around under the hatch and you would have smelled burning rubber.
As Blue Thunder said.
Theres no starting to go. |
Originally Posted by blue thunder
(Post 2670499)
thanks for the tips guys, good news is coupler was fine, had a couple valve cover bolts back out and replaced them today, all tight and dry again:)
| All times are GMT -5. The time now is 07:43 PM. |
