-   -   Popping sound (https://www.offshoreonly.com/forums/general-q/194508-popping-sound.html)
clpbs 09-03-2008 07:18 AM
Popping sound
I need some help. I have a customers boat with a pair of 496's and one of them under a hard load or trying to get on plain quickly it sound like a machine gun going off in the intake, back offthe throttle a little or when bringing it on plain going slowly it's fine to around 4k then it starts popping. Fuel pressure is 40, no codes, I ran the engine on a separate tank, did a injector drop test on all eight injectors, compression is good, no abnormal sounds coming out of the engine like lose rockers. Any ideas are welcome
Rookie 09-03-2008 07:25 AM
sounds like detonation?
OldSchool 09-03-2008 07:35 AM
The last time that I heard that on my boat, I was missing a few pushrods. :eek:Didn't make that noise until under load. Good luck, I hope it's something minor for you. I'd pull a valve cover and take a look.
ezstriper 09-03-2008 08:17 AM
plug wires and or coil packs...
BY U BOY 09-03-2008 08:34 AM
Stuck valves or timing will do that also.
SB 09-03-2008 08:47 AM
Typical when a flat tappet cam has severly worn lobes. But, that's not this engine of course.
If all paramters look fine (especially ignition) I would highly suggest removing valve covers (as mentioned) and look for broken valvesprings. if not, maybe springs have lost tension.
Bad valve/valve seat also.
-Do compression test . Oops. I see you did that. By any chance, did any of the cylinders have a much higher reading than the others ?
-Check ignition . Cam/crank sensors. Coil packs. Wires. Etc,etc. TPS / Battery + charging system / all grounds
-Pull Valve Covers .
-Test fuel.
clpbs 09-03-2008 09:42 AM
I'll check the springs but remember this is a 496 with about 114 hours and I've worked on a lot of 496's and have never see spring isues even on motors with high hours and ran the motor on another fuel tank.
SB 09-03-2008 09:57 AM
I once received a brand spankin new GM 5.7L truck engine from local Chevrolet Dealership that had no spark plug holes drilled or tapped on one cylinder head.
Boy did that one give me a buzz kill. LOL.
Point is: never assume anything.
Was any work done on this motor recently ie: right before this issue came about ? Any other problems customer noticed before this came about ?
Edward R. Cozzi 09-03-2008 10:15 AM
All it takes is a little rust on the valve stem after sitting for a while. The pushrod becomes bent or broken when you crank the engine. Usually it's an exhaust valve, but some engines do not discriminate and take out intake pushrods as well.
We see this down here with our high humidity and boats that stay in the water without regular use.
Edward R. Cozzi 09-03-2008 10:17 AM
I once nearly went crazy trying to install a new AC spark plug that had no threads! I didn't notice it when I gapped it. (I was just a kid back in those days).
lookinforboats 09-04-2008 07:56 PM
replace spark plugs but make sure you use AC delco from a current Mercruiser catalog. number has been superceded and there were alot of problems with the denso spark plugs. Im surprised you didnt store a misfire code in freeze frame though. Did you check freeze frame or only current Faults?
hp500efi 09-04-2008 08:20 PM
bad boost fuel pump will do that....swap pumps and see if the other motor does it...replace..
clpbs 09-05-2008 07:13 AM
I did check store faults and there was none. hp500 I was thinking the same thing because when I checked the vacuum that it would pull it fell a little short of the spec.
mcollinstn 09-06-2008 02:00 PM
if your fuel pressure is good WHILE EXPERIENCING THE POPPING (not just on the gauge idling), then look at ignition.
Yes, broken springs will cause popping too but a weak ignition will as well.
lookinforboats 09-14-2008 09:33 AM
just curious on what was the actual problem and what
resolved it. So we can store it in our mental databases
Yellow_ICC_OK 09-15-2008 06:55 PM
Flappers?
No way it could be the exhaust flappers could it? Sometimes they pop like this on my old 525 SC.....
clpbs 09-16-2008 06:46 PM
Well we will never know the the boat is now on the bottom. We just whent thrue Ike and its not good. My shop is ok but the marina is in bad shape.
lookinforboats 09-16-2008 10:21 PM
Sorry to hear that but glad your shop is ok
good luck joe
