Originally Posted by Griff
(Post 2678613)
In that case, maybe. I thought you were talking stock 575sci's. Oil temps are more relative. How are they???? are you running crossovers or recirc pumps???
I had the boost cranked up to almost 8# on my 525SC and still ran the 140* Tstat and recirc pump. It maintained nice consistent temps from 145 at idle to 155 after WOT runs. |
I dont know how else to but this. I depends on the tune in the ecm. The engine has to reach the proper temp or the ecm will just think the engine is still in worm up mode. If you want to call someone you need to call Mark @ Precision Marine on efi and tunning he is good. Also Dustin @ Whipple
(Post 2678359)
Go with 140* Tstats. There is no reason to run it colder.
Originally Posted by Michael Garibay
(Post 2678512)
What about with superchillers and 3 1/4" pulleys and running 7 lbs boost? Would that be a reason for running 126* stats?
| All times are GMT -5. The time now is 10:44 AM. |
