Steering wheel replacement?
I am planning on replacing the steering wheel on my 98 353 Formula. What do I need to know when I go to match it up?
Thanks |
depending on what you buy, i had to change the hub to match the pattern on the new wheel, mine is a 98 also, you should i think have the same shaft i thought mine had a slot and keyway.
Originally Posted by augie58
(Post 2684995)
Thanks or you can give me a call at the number below. Hope this helps. Brian |
direct bolt up was easy
http://www.offshoreonly.com/forums/s...t=92301&page=2 call Ryan,he took care of me when I did mine:drink: http://www.kineticanimation.com/ |
| All times are GMT -5. The time now is 08:19 AM. |
