Imco PS reservoir leaks
1 Attachment(s)
My Imco PS reservoir leaks through the breather in the cap when in rough water. Anyone have a cure for this? Different cap or replacement breather?
The PT-9 in the pic is my part. |
I have the same reservoir in my '03 386, it leaks in rough water too.
Sounds like it is building pressure and bleeding out, you need a vent of some sort or run a different reservoir with a vented cap such as this------> http://www.cpperformance.com/SearchR...CategoryID=372
There are a couple to choose from in size and application. I can also get you a bung and cap to weld in place of your existing setup if you are a weldin' man :cool: Hope this helps, let us know if we can help more. Thank you Brian |
| All times are GMT -5. The time now is 06:40 PM. |
