The best conventional 40wt I can find.
Brad Penn 40wt.
http://www.bradpennracing.com/Products/SAE40.html Al 0 Cr 0 Fe 1 Cu 0 Pb 0 Tn 0 Mo 1 Ni 0 Mn 0 S 0 Ti 0 K 1 Bo 3 Si 8 Na 241 Ca 1634 Mg 582 Ph 1350 Zn 1595 Ba 1 SUS Viscosity@210*F 78.1 cSt Viscosity@100*C15.05 Flashpoint in *F 430 Loaded with anti-wear ZDDP. |
How do these numbers compare to Valvoline VR-1 40 weight? Currently using this oil.
I have had excellent luck with 40W Valvoline racing oil. I have taken numerous motors apart after running & the were in good of shape as there were with Mobil 1. A lot less costly
| All times are GMT -5. The time now is 03:03 AM. |
