Kendall 20W-50
Kendall 20w50 API SL a bit low on ZDDP
code: -------------------------------------------------------------------------------- 20w50 Mo 54 ph 1076 zinc 1068 mag 15 cal 2051 silicon 0 Cst 18.64 Visc 50w |
Kendall Gt1 turbo oil isnt green anymore. Started using Rotella T when it changed.
You can still get the green oil. It is now called Brad Penn. It is made in PN right where Kendall use to be made.
| All times are GMT -5. The time now is 08:21 PM. |
