broken spark plug
How can i get a broken spark plug out. The threaded part is still in the head.The nut part sheard right off.
Originally Posted by Ken N
(Post 2690754)
Soak it down with pb blaster, see if you can get the porcelin broken out, use a ez out to get into the center and try that, I have used that and has worked for me..Rob
Originally Posted by ezstriper
(Post 2690826)
tough one???? if you can get a drill straight in I'd try that first before pulling the head. hopefully it was a defective plug and not siezed in the head. good luck
Originally Posted by tcuda499
(Post 2691411)
Let me guess...Champion plugs? I have had it happen to me twice in cars with Champions. I did what ezstriper said and it worked both times.
If any thing falls in the combustion chamber while you're drilling, pull the head off and clean it out. A small piece can cause a lot of damage.
broken plug
I think i will play it safe and pull the head.
As stated ezstripper his method or try using fast heat from a cutting torch for 20 seconds then drive in the easy out( use the style that looks like a reverse thick cork screw)with a hammer, not too hard and you will get it out. I have done at least 50 plugs and none have beaten me.:angry-smiley-038:
| All times are GMT -5. The time now is 01:19 PM. |
