| alecsammy |
09-21-2008 09:47 AM |
sea water pump housing for fuel pump needed
After chaseing my tail ,I believe this is the problem . I've been running a Mallory 4110m electric fuel pump with a mallary regulator that has a dump valve. I had it set a little over 6 psi and ran a line to the dash ,, ran the boat wide open and the fuel psi went to 1 psi . I then bump the pressure up the 7.5 ran it again and the pressure dropped to under 3 psi. The pump is has low has I could get it in my boat. No more playing with the electric fuel pumps , I have a 98 502 Gen-6 engine and need a good used sea pump with the mechanical fuel pump adapter. Does anyone know someone that would have a good one for sale and if so do you have a contact phone number or email . Thanks Alec
