-   -   cam selection (https://www.offshoreonly.com/forums/general-q/196040-cam-selection.html)
prostockcat 09-24-2008 08:07 PM
cam selection
i have some 502 mpi's with MEFI 1 computers. what is the largest camshaft i can put in these things without having to remap the ecu's. i believe the stock cams are .510/.510 part#431-9830. thanks
JRider 09-24-2008 08:19 PM
I would say its probably not worth putting a bigger cam in if you dont remap.
Griff 09-25-2008 01:20 AM
You can't make any substantial engine mods without a reprogram of the ECM.
If you want any gains, the ECM has to reprogrammed.
KAAMA 09-25-2008 07:41 AM
........aside from all of that (all things considered), if you still want a good cam profile that will be custom designed for your application, then RMBuilder/Bob Mardara of Marine Kinetics is N.Y. is the man to call---he's the cam expert. (585)654-8583
kennyo 09-25-2008 08:38 AM
I know some guys running the 731 crane with headers and no remap. seems to work for them.
DORaymond 09-26-2008 09:35 AM
Is the 731 cam suitable with the MPI, or was it only used withe the carbed HP500's?
