-   -   Drive lube Testing (https://www.offshoreonly.com/forums/general-q/196107-drive-lube-testing.html)
Prater 09-25-2008 04:14 PM
Drive lube Testing
Does anyone do a test on drive lube to determine wear? I will be changing the lube soon on my TRS drives and would like to send in a sample. The starboard drive was rebuilt by Dollar a few years ago and does not have much time on it, the port drive I dont have any idea on...
GO4BROKE 09-25-2008 08:32 PM
I haven't seen one on drive oil, but the amsoil website has one on gear lube. top 3 were amsoil,GM synthetic, and Mobil 1. Since learning Merc high perf lube isn't synthetic( but priced like it is) I'm switching to M1 when I service the drives next week.
07DominatorSS 09-26-2008 07:48 AM
I've done tests on gear lube before. But, yeah, here is a good reading on gear lubes if you have some time.
https://www.amsoil.com/products/gear...hitePaper.aspx
I use a company for oil analysis called "The Oil Analysis Lab" in Spokane, Washington. I use them because they are an independent lab, and secondly their test results are very easy to read and understand.
cigrocket 09-26-2008 12:42 PM
Royal Purple is great for TRS. I ran it before I got Konrads
ezstriper 09-26-2008 02:17 PM
I second the royal purple !!!!
stevesxm 09-26-2008 04:36 PM
i find the amsoil propaganda just to breathless to be believeable. it may well be as good as they say but ive never seen any evidence that it is materially better than anything else the the full syn catagory.
Prater 09-26-2008 07:10 PM
I am not looking into the tests of comparable oils, I want to test the oil in my drives for wear. 07DominatorSS thanks for the oil analysis company.
Ryan00TJ 09-26-2008 10:03 PM
M1 is very good gear oil. However it will not protect the gears and bearings if water enters the drive. I had that problem last year and lost my gears. The Merc and Amsoil will keep this from happening. Just my experience.
sleek1 01-27-2009 04:24 PM
If you get your lube tested I would be interested in seeing the results, hours, brand, drives? I just switched to Amsoil even though my Merc lube looked new after one season. I only had a minute amount of metal powder on the magnet. I also switched to the Monster Magnets.
4mulafastech 01-28-2009 08:38 AM
I would like to learn more about these monser magnets. Do you have a link?
Thanks.
minxguy 01-28-2009 04:33 PM
Any lab that does engine oil anaylis can do gear oil. It would be a better comparison if you could send a new unused sample with the used sample for comparison of YOUR oil.
Try Stavely Services in Atlanta.
Ken
Prater 01-30-2009 05:40 PM
I have been on the road for quite a time. Once I get a chance I will get it done. I am at tybee island right now, then home for a week and of to San diego...
sleek1 01-30-2009 06:53 PM
Thanks.
4FRMULA, I have the website book marked at home. I'll post it for you tomorrow. Supposedly they are 4 times stronger than the factory magnets. I think they were $9.95 each.
CanDo 01-30-2009 07:24 PM
test
I would not bother testing the drives oil.
07DominatorSS 02-05-2009 03:04 PM
Find that website yet??
sleek1 02-06-2009 12:15 PM
Thanks.
I finally took the time to find the link.. http://www.jrmarine.com/
Good luck, hopefully they'll be another layer of protection.
