2007 Mercruiser 525 efi
What heads are on these motors?And are the bolt patterns the same as a big block chevy?
I think the heads are made for Mercury, and they have a different bolt pattern than the std. BB. Do a search here on OSO.
Edelbrock heads made for Mercury Racing. Standard bolt pattern for bolting on to block, and manifold, different exhaust flange bolt pattern.
Originally Posted by Whipple Charged
(Post 2706715)
Ditto!:cool-smiley-011: |
How far off are the holes can a set a lightings be altered to fit
You need to weld up 4 of the bolt holes and redrill them. You will also most likely need to add about a 1/4" of material to the ends of the header flanges to make room for the outside bolts.
Any one have a pic of the gaskets that show the difference in the holes?
just buy a gasket and use it as a template
I have Qty 4 - 525EFI Heads for two engines For Sale, with 70 hours of running time. Heads are complete with valves & springs, no rockers.
Ray |
Originally Posted by skaterboy
(Post 2711486)
Ray / Nic |
Did you sell the heads ?
| All times are GMT -5. The time now is 05:52 AM. |
