-   -   Just getting my rebuilt motor back, engine oil thoughts..... (https://www.offshoreonly.com/forums/general-q/196964-just-getting-my-rebuilt-motor-back-engine-oil-thoughts.html)
cloudmaster_321 10-09-2008 01:22 PM
The builder of my motor doesn't want me to use the Mobil 15W-15 that i was using. He says it's not the same quality it once was. He isn't trying to sell me on the oil he uses but did recommend Brad Penn racing 20-50. He also said he liked the amsoil 20-50 oil. Any thoughts?
Right now i have break in oil that will be coming out shortly.
DareDevil 10-09-2008 01:42 PM
Run VALVOLIN VR1 racing 20/50 !
07DominatorSS 10-09-2008 03:01 PM
AMSOIL 15w-50 Dominator Racing Oil
o2man98 10-09-2008 03:54 PM
Yes, that would be the one.
https://www.amsoil.com/storefront/rd50.aspx?zo=1132530
BadDog 10-09-2008 07:00 PM
Do a search on Hydorcruiser posts. Mobil 1 15-50 did change formulations from Red to Gold then to Silver cap. If I read things right Mobil 1 15-50 Silver cap is a good buy considering you can get 5 qts. at Wally World for 22 bucks.
cloudmaster_321 10-09-2008 08:51 PM
I know, i have been running the mobil one silver cap. Didn't think i was having any issues till this. Also found out my oil temp was never making it over 130 degrees..........
I having the oil thermostat installed that CPP sells. Should fix that problem.
cloudmaster_321 10-09-2008 08:54 PM
So no opinions on the Brad Penn oil?
BillK 10-11-2008 03:29 PM
Cloud,
I am not going to make an oil recommendation other than ..... if the builder is warrantying the engine, I would darn sure use what he says to :)
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Racerngr1 10-12-2008 10:39 AM
I haven't heard of the oil that your asking about; however, I have run the Royal Purple in pretty much everything I own, especially the boat and have been very happy.
Smitty 10-12-2008 11:37 AM
Brad Penn is what alot of the drag racers use, as well as what 4 engine builders that I know recommend.
RBeyer 10-12-2008 12:39 PM
My builder insist on 50W Valvoline. Never had a problem. Procharged Injected 468 720 HP. Second bulid in 6 years no problems.
Griff 10-13-2008 01:21 AM
I have heard very good things about the Brad Penn Oil.
I run the Mobil1 15-50 silver cap and never had any issues.
Carder 10-13-2008 02:00 PM
When Tyler rebuilt our engines he also used the 20/50 Brad Penn. We have continued to use it... well priced, no troubles at all, plus its GREEN.
Carder
