-   -   Anyone try spinning a 350 mag mpi backwards? (https://www.offshoreonly.com/forums/general-q/197121-anyone-try-spinning-350-mag-mpi-backwards.html)
HaxbySpeed 10-12-2008 08:58 PM
Got any ideas why it wouldn't work..
Griff 10-13-2008 01:13 AM
HUH?????????? Why would you want to?????
ezstriper 10-13-2008 06:38 AM
you will have to change the cam to a reverse rotation cam, a special delco dist and rear main seal...Rob
HaxbySpeed 10-13-2008 02:25 PM
I've got a customer who wants to repower an older inboard boat that has counter rotating 260 mercs. The transmission cannot be converted to spin in reverse, and there is no room for a different trans..
The cam and distributor aren't a big deal and the crank trigger should work fine in reverse, I think the new ones might have a cam sensor as well... The injectors are batch fired.. I think it can be done unless there's something simple that I'm missing. Which is often the case.. :rolleyes:
ezstriper 10-13-2008 02:44 PM
they still sell reverse rotation gm small blocks already done...Rob
HaxbySpeed 10-13-2008 02:57 PM
EFI? :eek:
jrz 10-13-2008 03:33 PM
I recently had a 350 MPI changed to reverse rotation for the same reason. 1951 Chris Craft. Everything seems to work fine.
