-   -   No Fire on a 540's (https://www.offshoreonly.com/forums/general-q/198041-no-fire-540s.html)
scandelous 10-29-2008 07:09 AM
No Fire on a 540's
I have tried everything I can think of. I have no fire to the distributor, I thought maybe it was a bad kill switch, but that checked out ok. I replaced the coil, the plugs etc., I even checked the air in the tires. Please help.:grinser010:
800XCR 10-29-2008 07:50 AM
If it has MSD, the box will be junk.
PatriYacht 10-29-2008 08:07 AM
Start with a 12 volt test light and see if you have power to the ignition module first.
x7734x 10-29-2008 08:13 AM
Have you ever had any voltage issues with your boat? If you have an MSD and run the ignition on less than 12 volts you can screw the ignition up.
cigrocket 10-29-2008 08:24 AM
If you have MSD. Swap the box from your other motor. or borrow one. One day it will fire, next day its a new Anchor. That's how one of my boxes went.
scandelous 10-29-2008 08:42 AM
I don't have an MSD box on either motor. I just have an MSD coil, that I just replaced, with no luck. The only thing I did electrically, was install a new breaker on the fuel gauge. I unplugged the breaker and still no fire. It first started out on one motor, no neither motor will start...
stevesxm 10-29-2008 03:11 PM
if you have an MSD and try to run it on ANY voltage , the chances are good it will fail.
Panther 10-29-2008 03:16 PM
Have you run a test lead on the positive side of the coil to see if you're getting power when the ignition is on? Also, while cranking put a test light on the negative coil wire and see if the light flickers.
Takes less than 5 minutes to verify this, then we can go from there.
Turbojack 10-29-2008 08:08 PM
Tell us al little more of what you have. EFI?, regular distributor and coil? or what?
scandelous 10-30-2008 06:19 AM
Blower motors with carbs, msd coil, reg. ignition. Motors crank only. Nothing is unplugged. All breakers are in good shape and operating correctly.
