trim sender wiring
simple question..I hope...but where does the trim sender/limiter wirining come thru at the transome on a bravo ? thanks Rob
On the top by the water inlet. Follow the wires from the sending units on the drive, you will see one bolt that holds the cup on the wires in place and keeps water out.
You can see the wires in the middle of one of the pics I posted on this thread. http://www.offshoreonly.com/forums/g...ghlight=gimbal |
Thanks, what i really need is where they come out and go on the inside of the boat,(guess I was not to clear on that sorry) somebody cut mine off when they changed engines for the previous owner, just now getting fixing this issue...thanks Rob
| All times are GMT -5. The time now is 11:25 PM. |
