-   -   Jetting (https://www.offshoreonly.com/forums/general-q/198532-jetting.html)
BenPerfected 11-09-2008 11:11 AM
Jetting
On a NA BBC with a single carb (mine is a Dominator), do you stagger the jets front to rear? Assume the impact of the PV's is neutral. I am looking for the amount of your jet stagger, if any vs. the actual jet size.
BenPerfected 11-09-2008 11:14 AM
Oh...also single plane intake manifold.
Griff 11-09-2008 12:45 PM
With the same PV's in primary and secondary, my 1050 on my 525sc was squared as stock. After I did some mods and rejetted, I bumped the secondaries up 2 sizes bigger.
BenPerfected 11-09-2008 02:42 PM
Griff,
Are your plugs approx the same color? Square jetted with 2 PV's I am rich in the front - 1&3 and 2&4. I am done for 2008, but just working on the 2009 plan :drink:
Griff 11-09-2008 07:36 PM
This was on my Pantera engine. All the plugs were pretty much white on the porcelain. They had good color on the base circle and they all looked the same. The fuel charge was probably more balanced on mine since it was going through the SC first and being forced in with boost.
fbc25el 11-10-2008 07:36 AM
I have a domminator on my 540. It was done by nickerson. It has 92 jets in the front 94 in the rear and 4.5 power valves in both front and rear.
BenPerfected 11-10-2008 12:01 PM
fbc25el,
Does your plug color indicate the same A/F ration in each cylinder?
fbc25el 11-10-2008 01:08 PM
Yes it does. Depending if it is real hot and humid I might hafto turn the idle air bleed screws a 1/4 turn in or out. I am also verry happy with nickerson's work.
