Converting 525EFI rods to floating pins...
If one were to want to use standard floating JE pistons on Mercury Racing rods, what would have to be done to the rods (bore and bush) "or" is the pin still a standard .990 that is press fit into the rod.?
Meaning will the JE pins press fit into the Merc rods?
Just curious....
Thanks,
Dave
Just curious....
Thanks,
Dave
Dave,
Just make sure that you dont actually "press" them into the rod. The correct way is to heat the end of the rod in a rod heater to a specific temperature so the pin will simply slide in and then lock in place as the rod cools.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Dave,
Bill Koustenis
Waldorf Md
Bill Koustenis
Waldorf Md
lucky strike
08-02-2004 10:53 AM
