-   -   Marine grade plywood (https://www.offshoreonly.com/forums/general-q/19892-marine-grade-plywood.html)
283CHECK 03-11-2002 03:01 PM
Any idea as to where to start looking for marine grade plywood in the KC area? I'm redoing some vinly in our boat and need to replace some wood.
Chris
283Check
traviss 03-11-2002 03:15 PM
Any good quality lumber yard should carry it, .. When you get the wood cut to size, give it 2 coats of epoxy to seal it.. It will last forever then. I used WEST SYSTEM epoxy when I did the work on the century.
waterbum 03-11-2002 03:33 PM
Try Shutte Lumber on Southwest Blvd. Got mine there a few years ago @ about $50 a sheet.
Good Luck,
Doug
