-   -   advice for best solid roller cam 609 (https://www.offshoreonly.com/forums/general-q/199766-advice-best-solid-roller-cam-609-a.html)
ezstriper 12-06-2008 08:07 AM
Making the power will not be a issue...spinning to 6k at that power you better have drives standing by to change like spark plugs ! I would go with a hyd roller and lower the max RPM and shoot for 5500-5600 max, it will make a big differnce when come to keeping drives together....Rob
KAAMA 12-06-2008 08:10 AM
The nice thing about using a shaft mount style rocker system is that it will also eliminate the need of a stud girdle or a rev kit and of course pushrod guide plates. I have always been told that the weakest link on a BBChevy is the valve train---especially with a stud mount rocker arm system.
By the way, RMBuilder/Bob Madara also designed the cams for my 565cid N/A engines about 4 years ago. There were some special things I asked Bob to do with my cams concerning idling quality..i.e. shifting, drivability, etc, and I am very pleased with the turnout.
RMBuilder/Bob Madara Marine Kinetics N.Y. 585-654-8583
formulaok 12-07-2008 07:22 PM
I remember reading where Bob Teague had said that he had seen some guys running the Bravo drives to around 6000rpm with good luck, but never experienced it for myself. I think he was talking about when the racers ran the pre XR era drives and they were trying to make them last. My thoughts were if it could turn that high, I could keep the torque down and save drives. Am I wrong to believe that a late model xr can handle the RPM?
Griff 12-07-2008 09:36 PM
It will handle it, but for how long, who knows. It might last 30 mins, 30hrs or 230hrs. My bet would be somehwhere in the 100hr range if you are very nice to it.
jeff1000man 12-07-2008 11:43 PM
I have allways read that the Bravo would rather spin to a higher RPM, than be lugged down with a bigger prop.
I have never tested this out, but how did this thread get off track? Did a cam ever get ordered? I would like to see what the specs were on that.
formulaok 12-08-2008 01:29 PM
I am going to call bob and talk to him about what he thinks. Teague recommends a HR custom grind that have it is
258 - 266 duration
.647 - .647 gross lift
lobe sep. 114
Operating range to 7000RPM
They did tell me this went into their large cube N.A. motor and that they stay away from the SR only because they have to warranty their motors and have no control of the end user.
I am not yet at all convinced by Teague's guy on the cam recommendation, I am going to talk to Bob Madara before doing anything else
RunninHotRacing163.1 12-08-2008 01:36 PM
Originally Posted by formulaok (Post 2753934)
Yea i am definitely going with the t & d rockers now. My headers are the big tube ones. Warren, I am interested in any info on that cam you were speaking of.
Bob,
Please advise of what you would do.
Sam
405-850-0515
Formula spoke to RM@ Bob on friday and he was walkin out the door and heading to PRI @ Orlando till Dec 15th ,if you cant get ahold of him ... :ernaehrung004:
I'd wait for Bob,you'll be glad you did
formulaok 12-08-2008 04:57 PM
I've got nothing but time until next spring!!
smiklos@sunprint 12-08-2008 09:06 PM
Bravo vs RPM
I have used bravos at 7600 RPM 613 hp with small blocks in our old B class boat. My experience is torque killls them not rpm.
Steve
formulaok 12-09-2008 10:39 AM
thanks steve
