-   -   Raw Water Pump Change over (https://www.offshoreonly.com/forums/general-q/199851-raw-water-pump-change-over.html)
BajaExpress 12-06-2008 09:16 PM
My express crusier has 454 330HP engines with Alfa drives.
Can I elimate the outdrive pumps and install crank mounted pumps and through hull water pickups for better cooling ?
How reliable are the crank mounted pumps?
DareDevil 12-06-2008 09:49 PM
I would leave them ,just make shure that the impeller is good.
I would put a water press. gauge in the boat ,thatway u be more secured.
But they work fine and actually are lower in the water then other PU .
Griff 12-07-2008 01:22 AM
Sounds like a lot of work and money for nothing. The pumps in the Alpha's should pump plenty of water.
DareDevil 12-07-2008 01:48 AM
Griff,,,,how come we always think the same but you find the better words ?
Are you a lawyer ? LOL
ezstriper 12-07-2008 09:11 AM
well to buck the other replys, you can do it if you want, need to put a scoop type thru-hull in the bottom of the boat, seacock on the inside along with a strainer, then mount up either a std merc inboard/bravo or crusader pump and braket setup, but the only thing i see you would gain would be the ability to change the impellor with out pulling the boat out of the water, unless the internals of the drive is corroded badly...Rob
boatman22 12-07-2008 11:43 AM
1 Attachment(s)
BajaExpress, if you decide to go with crank mount pumps, I have 2 brand new Johnson F5B-9 crank pumps that I will sell.
Griff 12-07-2008 01:51 PM
Definately not a lawyer. A lawyer would have typed 2 paragraphs to say the same thing:D
DareDevil 12-07-2008 01:52 PM
LOL:evilb:
ezstriper 12-08-2008 06:18 AM
and no one here would have had a clue what the hell you said !
