Originally Posted by WAGS382
(Post 2755491)
Bill
Thanks for the advise. I agree with you that I need to find the problem. I think it is a mild case of water reversion. If I pull the O2 plug when idleing I get water vapor. The back cylinders (7and 8) were not affected, the others have a straighter shot at the exhaust valves. Kamma I was told not to use the copper berillium seats because they are too soft and won't transfer heat properly. I was also told not to use the propane seats because they are too hard. I am not sure who to believe. Learn sumtin new every day |
Originally Posted by RunninHotRacing158
(Post 2756099)
I was told not to use the copper berillium seats because they are too soft and won't transfer heat properly?????????? :rolleyes::eek:
Originally Posted by KAAMA
(Post 2755592)
Yes, I have AFR heads w/230hrs or so, but I am not currently experiencing any seat problems---at least none that I know of at this point. I run Stellings full length tubular dry headers. The cams I am running (hyd roller) are easy on the valve train and have very little overlap....so, pretty slim chance of any reversion. The cams came from RMBuilder.
A few weeks ago there was a thread regarding "Copper Beryllium" seats and it sounded like they are supposed be the chit as far as durability (rust), valve bounce dampening effect, but I truely do not know either. I think I may have asked my engine builder at one time a few years back and I forgot what he said. I wouldn't mind using copper beryllium seats the next time I rebuild. Laz, what is your take on copper beryllium seats in either a steel or aluminum head? www.mesaracingengines.com |
Laz
Thanks for your advice. Jeff |
(Post 2756099)
| All times are GMT -5. The time now is 01:27 AM. |
