water pres
Help please, where I can install water presser gauge? On the block or on the intake manifold?
either side of the block or the t stat housing.
What motor/year? |
In the block drain plug hole or in the intake manifold. The ones in the block drain tend to clog easily if you run in any shallow water.
Originally Posted by PJDiesel
(Post 2755674)
What motor/year? |
25psi is about the max you want. You shouldn't being blowing hoses even with 40 psi though.
Originally Posted by Griff
(Post 2756032)
Have you back flushed it to look for impellor parts clogging it?
High pressure before cooler and lower pressure after the cooler. |
I agree, check for an obstruction in the oil cooler. Water should flow through it almost as fast as a straight hose.
(Post 2756663)
is this a new problem ? if so what did you last change also I run W.P. gauges at my helm also run pressure relief valves and dumps off the side
| All times are GMT -5. The time now is 04:42 PM. |
