Originally Posted by schiada.cat
(Post 2756623)
If you can post a picture that would help, I will try to get one but I am out on the road this week.
Its about 12 inches long 5 inches wide with normal water neck openings at each end. It is shaped like an "S" with one end rotated 45 degrees up and 90 degrees to one side and two small bolt holes tapped into a thicker casting area near one end to support it to the face of the blower |
compared your photo to what we need . Those are for the smaller blowers...the ones we need are about the same size but have a different offset and are a one piece casting which is thicker. Yours fit the 177 and smaller blowers, we have the 250 housings.
thanks for the effort |
| All times are GMT -5. The time now is 06:39 AM. |
