oil/ps cooler and filter system ???
Hi All,
I would to replace both coolers and oil filter housing along with lines and block adapter. I have a 502 gen6 almost 500 hp. I'm on a tight budget see some prices are cheap and some very costly. I have read articfriends thread on oil cooling but need to get some part number to buy this equipment . Can someone recomend a good place to buy all these items at a fair price or any other suggestions. Thanks Alec |
I used a remote filter adapter from Rex marine it is pricey uses a fram racing filter, I use a K&N I think it is 5001. I am using all -12 oil lines with the aeroquip fittings $$$$. I do not run a combo cooler the pwr steering and oil cooler. I was unable to get the 3/4 oil filter block adapter to work it kept leaking so I used the factory one with larger fittings
We would be happy to give you a quote on the parts you need, give us a call 302-521-0123 or email [email protected]
I have an original HP500 (motor was running when I took it apart...no metal) set-up that I will sell you! Budget in mind. The lines, oil filter adaptor, brackets and cooler. All you will need is the oil filter/ thermostat component. Let me know.
Dave |
| All times are GMT -5. The time now is 09:53 AM. |
