Originally Posted by 26 Spyder
(Post 2760228)
What he said.
The slave solenoid is a common problem on Mercs. The longer the boat sits without use the worse it can get, especially in humid conditions. The solenoid is a "self cleaning" design so the more you use it the better it gets, usually clicking it a few times will clean it off so it will work fine, until you park the boat again for a week or 2... They are inexpensive so just replace it... |
Originally Posted by kreed
(Post 2760101)
starter relay?
The starter was rebuilt with new solenoid, and bench tested in front of me (it worked before I rebuilt it, but since it was out, didn't want to take any chance) Not sure if this matters, but it is the smaller lighter high performance starter. When it works, works fantastic! |
Originally Posted by Thunderstruck
(Post 2760420)
Power to the starter motor is only one piece of the puzzle. Power to the starter solenoid comes through the slave solenoid from the + terminal on the starter motor, the same terminal the battery is hooked to.
a little on the extreme side but we had this happen to a 454 mag and the risers were leaking and there was water in the cylinders. not for nothing but pop out a spark plug and check. good luck.
1 Attachment(s)
Originally Posted by 2Slow4me
(Post 2760667)
Is that the same as the slave solenoid?
Short across the two big poles on the top of the solenoid with a screw driver or a big jumper wire and the motor should start turning over.
Originally Posted by 98itrwhite
(Post 2760712)
Funny you mention that, never heard of that before. Similar thing, this summer was trying to help out a guy who could start one engine is his cat. Tried another battery, just click and nothing. He called a buddy who told him to take a plug out, and gas poured out. took out all the plugs and gas just poured out, and looked like the float got stuck and was just poring fuel into the engine. Didn't go anywhere that day! |
(Post 2760746)
I had one of those fail on my gibson, crusader big blocks, looks the same....wonder why they are even used ?? wonder if you just by pass them ?? the starters used std gm solinoids ?? just a thought...Rob
Originally Posted by ezstriper
(Post 2761609)
BUT, those slave solenoids are a pain. I carry an extra and of course there's always the jumper wire/screwdriver. |
| All times are GMT -5. The time now is 09:38 AM. |
