Dont build a 12x12x12 box. remember to calc based on internal volume. also use 3/4 " wood. not 1/2" make sure to glue and screw the box and caulk it too.
i have a box with 2 alpine subs they are 10 inch you can have for 125 plus shipping i paided over 500
The simple solution is to just use the engine compartment as an infinite baffle. Unless you're really trying to make super low frequency bass, an infinite baffle enclosure is really efficient and doesn't take up any space on the boat or add unessesary mass. And no, the engine compartment does not have to be sealed for it to work right, the distance from the front of the sub around to the back just needs to be longer than the wavelength of the lowest frequency you are trying to reproduce. Not really that hard given most music you're going to listen to on a boat doesn't really need super low frequecies (20hz), just a lot of 40hz and above.
Originally Posted by phragle
(Post 2794833)
varies on the sub. get the sub make and model number and get ahold of the builder.
Originally Posted by Griff
(Post 2794881)
Exactly.
Look up the sub online and find out the specs. It should give the proper cubic feet needed. John jr |
| All times are GMT -5. The time now is 01:44 PM. |
