-   -   boat will not start! (https://www.offshoreonly.com/forums/general-q/200457-boat-will-not-start.html)
caseyh 12-20-2008 07:19 PM
:(i have a 2000 25" baja ol with a 502mpi. it will not start but it will trun over. the fule pump will not prime up and the gages will also not come on. all the accories work trim, trim tabs blower, nav lights and gage lights,etc. i was loading it on the traler today (yes in shorts, t-shirt and 77 dgrees partly cloudy got to love louisana) and i was in and out of gear then it just died and would not crank up!
DareDevil 12-20-2008 08:12 PM
Check the egnition on the engine,,what kind do you have ????
midwest272 12-20-2008 09:17 PM
Sounds like your not getting power to the ecm. I think there is a 15 amp fuse for this, if the ecm does not have power the fuel pump will not prime. This is seperate from the cranking system.
And it's a whopping 10 degree's here so don't rub it in.
1BIGJIM 12-21-2008 09:11 AM
Thats warm, its 6 below and wind chills of -30 here:eek:
The only good thing is, my man cave (garage) is heated:drink:
offshore2 12-21-2008 09:21 AM
You might want to look at the kill switch.
Pwrbt33 12-21-2008 10:27 AM
Like already said ck the kill switch first and wiggle the key switch to make sure you dont have a bad one. Then open the hatch up and ck the red resetable breaker in the engine electronics box. last I would check the harness plug at the engine and finally the fuse at the starter. If that fuse goes bad you will lose all the items you have just described. Use a test light and see if you have voltage at the starter lug and at the top side of the fuse.
If you have any questions feel free to call me. I'll PM u my number.
John
caseyh 12-21-2008 04:20 PM
thisnk for the help! it was the kill switch the top part witch pushes the button was cracked and wouldnt push it in all the way.
Pwrbt33 12-21-2008 07:34 PM
Cool!! Glad you found it.
