Fuel Usage Triple Engine
CAn anyone tell me what the difference in fuel consumption between a 42' Fountain with (2) 525's vs. a 45' Sonic with (3) 500 efi's?
I can tell you my buddies 386 sonic with trip carb 500's uses about double the fuel of my 386 with twin 496's.
But you're comparing apples to oranges. What type of boating do you want? If you are overnighting you want the sonic. The fountian is 1/2 the size of the sonic, and probably considerably faster even with 1 less motor, definately cheaper to run, maybe not quite as smooth in big water. So to over simplify, whats priority #1? Speed or Cabin comfort? |
Originally Posted by GO4BROKE
(Post 2765303)
You will get a lot more feed back with more info...Where or what waters your going to run on, trailering or not, rack or slip, spending overnites, and how fast do you want to cruise, or if you like to WOT it alot.
Knowing this might give you more pleasure owning the 45 over the 42. |
I went from twins in a 38 to trips in the 442. I can tell you that I gave up roughly .5 miles per gal vs the twins. I love the trips from a reliability standpoint. I can plane on two if one goes down. I do my own minor maintenance so oil changes, filters, plugs are not that bad. I will probably not go back to twins after owning trips.
What about insurance increase for trips? I believe the companies do not like them.
Originally Posted by LCPaver
(Post 2765231)
Insurance is higher with trips. I live in Florida, so we get slammed anyway. There are only two companies that will wrtie wind coverage and trips in Florida.
There is definitely less stress on the drives with trips vs. twins. |
(Post 2765309)
Triples are way more expensive no matter how you look at it. More oil to change, drives to service. fuel to burn.
(Post 2765231)
42 fountain is all you................ |
| All times are GMT -5. The time now is 01:35 PM. |
