Bow Lights
I when I turn my bow lights on ( not my navigation lights), it trips my breaker within 15 seconds every time. Do I have a short, not enough amps?
What bow lights if not the nav lights???????? Do you mean docking lights???????
And yes, you most likely have a short or bad ground. |
Yes, the bright lights on the upper portion of the hull at the tip of the bow.
thanx |
lights
Maybe the circuit breaker is not enough amps,or is weak. Docking lights take a lot of juice. JOHN
Ditto, I have had a couple breaker get aged recently and trip prematurely, replaced with exact same breaker and problem solved. Start easy 1st, breakers are cheap.
1 Attachment(s)
mine put about the same as a flash light,figure they dont draw much
| All times are GMT -5. The time now is 07:02 AM. |
