by those cam specs..looks like that may be the limiting factor...Rob
The cam is plenty big enough but it really is old school and any hyd. flat tappet has trouble controlling the valves above 5000 rpm. I'd find a good cyl. head guy to do a valve job and set up a new set of springs with a little more pressure than Crane reccomends. Or just change to Crane 741 hyd. roller cams. They are tried and true and will get you 700 hp in a set-up like this. Btw, what ignition timing are you using? in a set-up like this I would use 30-32 degrees.
It would be good to try a set of 25 pitch props. No boost until 4000 rpm's suggests that you are lightly loading the engines right now. They may pull the 25's to a higher speed and show more boost at a lower rpm.
Ding ding ding on the timing. how much diferent timing did you use on the dyno? Did you try it to 32,33,34,29,28 etc?
You could have to much or to little. Carb should be fine. A lot of thes set ups historically used the twin 750's actually. Roller cam is a good idea, but there is no reason he shouldn't be spinning past 5k IF he has the right spring. Try adjusting the timing a little. Check and make sure the belt is not slipping. Do you have the notched pulley set up or the grooved pulley set up. That could be why you are not making the proper boost. What exhaust do you have on the boat. That could be slowing you down. Just other factors. If you had the arrestors off on the dyno, that is not the problem now. |
Originally Posted by Griff
(Post 2779667)
Thats a pretty good sized flat tappet cam. It should make good power to at least 5500-5700rpms.
Have you tried going down in pitch on the props to try and get it to spin faster???? I really can't see that you should have a problem making enough torque though to get past 5100rpms. What about the timing?????? Where is it set for full advance and what ignition are you running??? Let me know if you have any more thoughts. thanks |
Originally Posted by HaxbySpeed
(Post 2779653)
What valve springs are you running, and do you know what they're installed at? It's quite common for springs without enough pressure, or even the wrong style spring to produce bad harmonics causing minor valve float very early in the RPM range. On blown motors as the rpms increase and the float gets worse it starts to bleed cylinder pressure, losing boost and horsepower. Your engine basically hits a wall. Just a thought... :drink:
Originally Posted by PatriYacht
(Post 2781792)
I am Not real familiar with cam's and specs. does this crane 741 Hyd. roller have the same specs as what I have or would I order a Crane 741 to match my specs??. I am sure I am running 32 total advance. I am using a Crane Hi-6M running the SC650 Ing. curve. |
(Post 2781798)
Thanks for the input. All opinions are valued. |
(Post 2781805)
You could have to much or to little. Carb should be fine. A lot of thes set ups historically used the twin 750's actually. Roller cam is a good idea, but there is no reason he shouldn't be spinning past 5k IF he has the right spring. Try adjusting the timing a little. Check and make sure the belt is not slipping. Do you have the notched pulley set up or the grooved pulley set up. That could be why you are not making the proper boost. What exhaust do you have on the boat. That could be slowing you down. Just other factors. If you had the arrestors off on the dyno, that is not the problem now. I didn't do alot of timing adjustment on the dyno. i was letting the Dyno guy take the lead when testing. I am running a 16 Rib grooved belt. Not a Cog belt so I am sure I have some slipping How much ?? I have stainless Marine exhaust I have one of the engines out right now. Should I have My engine guy Test/look at the springs. I think I need to find a new engine builder in my area. I'm not confident with my guy as far as a blower motor he does not have alot of experience with blowers. If I switch to a Hydr. Roller cam what can I expext from that. |
cocktails,i put a 509 with 8.0 compression in a boat i had.i used a bds 8 71 with a pair of holley 750 carbs,msd 6m ignition,gm heads with ports cleaned up,crane 741 hyd roller&spring kit.this setup made 720 hp at 5600 rpm at 8 lbs boost,also had cmi headers,not manifolds.your 420 can easily make 8 lbs of boost.i think 32 or 33 total timing is right,i always lock the distributor advance on all blower motors so you have total timing all the time.one more thing to consider,are you getting enough air with the engine hatch closed,if i opened mine up 2 inches i picked up 2 mph.[more and cooler air]my thinking is your valve springs are to weak and won,t let the engine rev.i have seen it happen before.oh,i forgot to mention,i used[and still have]a 27 pitch 3 blade,slight cavatation until on plane,then hooked up real good.
| All times are GMT -5. The time now is 11:21 AM. |
