-   -   502 Service (https://www.offshoreonly.com/forums/general-q/201825-502-service.html)
SCSRIVERRAT 01-20-2009 10:32 AM
502 Service
Im Doing THE Service On My 502 This Year And ANY Recomendations Of What I Should Do Exactly WOULD BE APPRECIATED. It Has About 250 Hours On It And I Just Replced The Engine Coupler In August Thanks In Advance
obnoxus 01-20-2009 10:46 AM
stock 502?
Nothing,,,, keep up on oil changes, plugs cap and rotor.
500 HP needs valve springs at 250 hours.
No way you should have eaten a coupler at 250 hours either.
SCSRIVERRAT 01-20-2009 10:59 AM
I Appreciate The Help, Would You Do Fuel Filters As Well, I Am Going To Do The Water Pump And Impeller Jest Because I Spen Alot Of Time On The River And Sand Is Impossible To Avoid, I Lost The Coupler At Catalina Oncei Arrived In Avalon It Stripped All The Way Out We Think It Was Because I Got The Boat Out Of The Water But Everyone Said That The Collar On The Drive Should Of Gone First?
Griff 01-20-2009 11:10 AM
Plugs, cap, rotor, impeller kit with housing(not just the impeller). Fuel filter about every 100hrs. Grease gimbal bearing and coupler. Drive service-- change lube(every 50hrs) and pull drive to check alignment(every 100hrs).
johnny b good 01-20-2009 11:23 AM
Wouldnt hurt to check/replace your exhaust riser gaskets and exhaust shudder valves. My 97 502 magnums have a pcv valve I replace also.Clean flame arrestor.
SCSRIVERRAT 01-20-2009 12:21 PM
Awesome I Appreciate All Of The Help
Griff 01-20-2009 01:11 PM
Riser gasket replacement is a good idea as well. I would also remove the serp belt and have it matched up an auto parts store. Either keep a spare or replace and keep an old one for a spare.
SCSRIVERRAT 01-20-2009 01:27 PM
I Will Definitly To The Risers And All 3 V Belts Any Other Ideas
