-   -   purchasing 500hp rebuild parts ?? (https://www.offshoreonly.com/forums/general-q/202639-purchasing-500hp-rebuild-parts.html)
rssteiny 02-03-2009 06:18 PM
Where is a good place to get my rebuild parts for my 500 hps, such as valve train, lifters , rockers, timing set, gaskets, cam shaft, and so on.
Also what would be advice on these parts as to what to get , would like to pick up 50, to 75 more hp, staying with my stock gill exhaust, i do run msds so i can turn 5500 rpms.
Thanks in advance
formula 382 sr-1 02-03-2009 06:36 PM
Thanks in advance
Call Rmbuilder AKA Bob Madara of Marine Kinetics for the cam shaft and other parts he will hook you up. (585-654-8583)
skaterboy 02-03-2009 07:42 PM
If you are interested, I have most of the parts (used) you need (less the gaskets) coming out of a pair of 525EFI's with 70 hours.
I also have the complete Heads less rocker arms also.
Ray
rssteiny 02-03-2009 07:51 PM
Ray
pm me what you have and what you need for it. thanks
Baja_man 02-03-2009 08:12 PM
Along these lines, where can stock HP500 or 525 EFI valve covers be found?
